Old 06-29-2009, 12:41 AM
jhalphen's Avatar
jhalphen jhalphen is offline
Hi to All, Hi Fjonsey,
I've had good results using a wideband RF "Gain Block" (see pictures)
To get decent power, say 50mW, 100 mW,...1Watt, you're going to need a lot more gain than just adding an extra RF PA transistor. With the typical RF modulator, you will need 3 stages, 2 with high gain/low power + the final RF amp.
By using a Pro A/V modulator, you can get away with only 2 stages as these models can usually be cranked up to a pretty high output level.
For instance, looking at the spec sheet of the Blonder-Tongue AM Series agile NTSC A/V modulators, the output level is specified as +40dBmV to +60dBmV
That is 40 or 60 dB above 1mV defined as the 0dB level. If you convert to power on a 50 Ohm standard RF impedance,
42dBmV equates to 0.0032mW
60dBmV equates to 20.97mW
Hence the need for more power if you are to get any range for your transmitter.
Gain block RF amps are found in this E-Bay section:
http://business.listings.ebay.com/Pa...istingItemList
Mini-Circuits is still in business, Avantek also maker of interesting products, is defunct. I look for DC-1GHz amps or DC to a few hundred MHz. Personally, i stick to VHF Bands I & III and hate UHF because of its unpredictible field strength distribution in a house/condo appartment.
Also, from recent research i did on the frequency re-use of vacant ex-analogue TV bands, for instance in France VHF Band I will remain abandoned (so i am relocating all my transmitters there), VHF Band III is allocated to future DVB-MB digital radio broadcasting, a more advanced version of DAB radio, the UHF band remains committed to DVB-T television in SD & HD formats. The upper end of the UHF band (740-892 MHz) is being sheared off for "new digital services to mobiles", probably DVB-H H264 broadcasting to cellular phones.
To come back to RF power amps, each file name includes brand, bandwith, gain & output level.
As a low power, high gain "preamp", i like the Mini-Circuits ZFL-500:
20dB gain, +9dBm output, bandwith 50KHz-500MHz (see pdf).
As a high power final RF output chain, i like the Mini-Circuits ZHL-1042J:
20dB gain, +23dBm output, bandwith 10 MHz-4.2GHz (see pdf).
or the Mini-Circuits ZHL 2-8: 27dB gain, +29dBm out (a bit over 1W with full drive), bandwith 10MHz-1GHz.
To finish this long post, i feel it would be a worthwhile project to pool our knowledge here to achieve a sure & tried recipe of building block components so that each of us could enjoy OTA NTSC again via low-power TV transmitters.
Best Regards
jhalphen
Paris/France
