If the horizontal output transistor shorted, it probably took out a B+ fuse or fusible resistor in the power supply and maybe the voltage regulator IC. Also, Mitsubishis of this age are prone to leaking electrolytic caps. I finally got to the point where I wouldn't work on a Mitsubishi because I got tired of replacing 50 caps and cleaning up the mess they made. The ones from the '70's and early '80's were OK. They went downhill after that.
