Old 04-23-2009, 10:20 PM
AUdubon5425's Avatar
My New Keeper - '83 Sylvania E34-53
Thought I'd show a couple of pics of my new console, a 1983 Sylvania CLC254AK01 with an E34-53 chassis. It was built in Greenville by Magnavox/NAP. It has a nice picture, needs a couple of caps replaced, and whistles out the back. I don't think it is a remote set, but I haven't opened it up yet to confirm.
Oh, the pics were taken with no antenna attached.
Old 04-23-2009, 10:30 PM
zenith2134's Avatar
Cool. The NAP Sylvanias are usually very reliable sets. Nice looking set.
Old 04-23-2009, 10:37 PM
After those caps are changed, it looks like the picture would be perfect. I second the fact they hold up pretty well. It doesn't look like a remote set though, I looked at one like that last summer, but I may be wrong. The whistling is most likely a dirty anode connection. Discharge the CRT and clean the connector, cup and socket on the CRT with alcohol. Then put a small amount of di-electric grease on the cup. Sad to see the days of a tv on with no antenna coming to an end. Viva analog!
Old 04-23-2009, 11:22 PM
I think the E32's and E34's were among the last GTE designed chassis before the NAP takeover. They were kept in production for a few years (up until around '85) after the '81 buyout. I have one of the last true GTE-Sylvania's from '81, a 19" E32 chassis set, which is the 19" version of the E34 chassis.
Looking at the picture, I'm sure some new caps in the vertical circuit will fix it. While you're in there, resolder anything on the chassis that looks like it's been hot. I'm sure your set uses a 25" inline tri-pot tube similar to what was used in the early Zenith system 3's. That tube will give you a sharp picture if it's in good shape.
Old 04-23-2009, 11:55 PM
Well, you know about missing the obvious, right?
It couldn't be a remote set, with the push-pull power switch...
Old 04-24-2009, 12:22 AM
That's not always the case. I've seen some remote sets from the late '70's-early '80's that still had a pull on/volume knob. The switch was usually just a master power switch and the volume control was more like a volume limiter.
Your set, however, is non remote.
Old 04-24-2009, 12:40 PM
I have a friend with one similiar to this, on a wall mount. Probably been there since new. Every time I've ever been over there the set has been on. Still looks like new.
Old 04-24-2009, 12:56 PM
Very nice looking TV. The picture is very good for a 26-year-old set, IMHO, even if the set needs a few new capacitors. Does the TV still have its original CRT?
However, I'm wondering. How on earth are you getting such good pictures without an antenna? I looked at several websites that show only New Orleans' NBC channel 6 with its transmitter in Chalmette. How close are you to New Orleans' other network affiliates' transmitter sites? You must be in an incredibly strong signal area, within only a mile or two from the stations.
Old 04-24-2009, 01:11 PM
zenith2134's Avatar
Or the TV might just have very good fringe area reception. (nice pic with no antenna)
Old 04-24-2009, 02:12 PM
I'm not sure if it's the original CRT - I'm hoping to pop the back off this weekend to take a look inside.
Believe it or not, this set is next to my metal garage door and that is the worst area in the house for reception. I'll have to snap some pics of my '77 XL100 in the bedroom - I could pick up most stations without an antenna.
As far as how close I am to other transmitters, well remember we're on flat terrain, which I'm sure helps. Here's what's left on analog:
WDSU 6 - 1.2mi
WYES 12 - 1.3mi
WGNO 26 & WNOL 38 - 3.3mi
WPXL 49 - 4.6mi
WWL 4 - 5.7mi
WUPL 54 - 24.5mi
I could pick up WXXV on uhf from the Gulf Coast (77.5mi) until they killed analog transmission. I can also occasionally get WLOX 13 (75.0mi) if the wind blows the right way. I'm sure it helps that there's nothing between me and Biloxi but the Gulf of Mexico.
And, of course, the DTV box won't pick up anything without an antenna.
Old 04-24-2009, 07:24 PM
Opened it up, real clean on the inside, you can tell this came from a clean non-smoking home. The crt is a NAP with a Sylvania eia code, 25VHRP22. Lots of "Assembled in Mexico" tags on the wires inside.
The first screenshot is of VHF via cheap rabbit ears (WYES-TV 12)
The second is of the signal from the Quasar VCR - the tape seems to have a bit of degradation, and maybe the heads need cleaning.
Old 04-24-2009, 07:49 PM
That looks like a low hour set. Mine (E32 19") has about a million hours on it and it's still going; so, there should be a lot of life left in that one.
Old 04-24-2009, 11:12 PM
The "chassis" looks very small. I knew some TV manufacturers were putting small PC-board chassis in large console cabinets by the 1990s (Zenith had a console in the early '90s with a chassis so small, I swear one could put a hi-fi system in the leftover space), but I did not realize this was going on in the early eighties.
Old 04-25-2009, 02:50 PM
PunkTiger's Avatar
PunkTiger PunkTiger is offline
SW DXing
Hmmm... On that last picture, between the channel display and the control knob, is there some sort of sensor in that spot?
Old 04-25-2009, 03:24 PM
That looks like a light sensor that controls the auto brightness depending on room light. Shine a flashlight on it and see, the picture will get really bright. I have several sets with this. I like it as the light comes in right on the tv sometimes because of a picture window on the other side of the room. Very popular in the mid to late 70s into the mid 80s, a few companies kept the feature but not many after then.
