Ian, Have you also checked the flyback to make sure it is good? I would check that before doing any further work. Check the flyback and make sure there are no burn holes and also smell inside the can to make sure there is no burnt odor. I know I probably sound like a broken record on these posts, but flybacks were RCA's main weak point and usually the main cause of failure on those chassis. I'm only stating this because there isn't much point in doing all the other work if that isn't attended to first. As for the picture tube.... It probably has a 25XP22 which was a pretty durable tube. I wish you luck on the repairs, and you've got a pretty "high-end" set for it's time if you have remote!
Yes...the flyback is a possible problem on these sets, but it seems like the flybacks got better by the time RCA got to these sets...have not noticed as many cases of flyback failure on the 38's/39's as on the CTC-31's and CTC-16's.
To diagnose where the short is, I start at the end of the filter capacitor/resistor chain, farthest away from the rectifiers, and disconnect one branch at a time, and then observe the short checker lamp to see if a short is still present. If so, I continue disconnecting further back the chain till the lamp goes dim. If you get all the way back to the diodes and the lamp is still bright, its likely shorted diodes. |
