Hi Reece,
An AA5 with six tubes. I could never figure out what to call it. ![]() You're right about the inlay. It's a photo tape on top of the wood. The finish isn't too bad. I might try a restorer product like you mentioned. I haven't opened it up yet but by peeking in through the back it appears that the speaker has been replaced once. I think there is room for a higher quality speaker like you suggest. I'm not going for complete originality. I will completely recap it and use safety caps where appropriate. The speaker can't be seen anyhow. But, in the interest of some basic originality, were these small wooden sets usually shiny or have a satin finish? I saw a post on arf saying that they were shiny. I kind of prefer satin. John |
I just looked at the schematic of your set and found an RF amplifier stage directly ahead of the antenna. Many table sets of this vintage had RF stages, as not every city or town in which these radios were used had local AM radio stations. Because of this, the sets had to be built for long-distance reception, and were often used with outdoor antennas in fringe areas. Yours should work very well for AM DXing, although with only one IF stage it may have issues with separating powerful stations on the dial, say 1100 and 1110 kHz, especially if one station is 50kW and the other is much weaker.
I second the suggestion as to putting a larger speaker in the cabinet. If the radio sounds good with a 5-inch speaker, replacing it with a 5x7 or even an 8-incher will improve the audio quality quite a bit, especially in the bass range. The cabinet looks as if it should accomodate up to an 8-inch speaker, so I'd say go for it. The improvement in the sound quality will be well worth the effort.
Thanks for all the feedback on the speaker issue. I'll see what I can fit in to it.
The RF stage might be helpful to me. I listen to WBBM in Chicago at night, which is a bit far from Bath Michigan. I often use my GE AA5 or my Silvertone 6002, which is a Noblitt-Sparks 4 tube. When reception gets bad I use my HQ-160. The Noblitt-Sparks is amazingly sensitive. It truely has one IF stage. I'm not sure how to count them in the Sonora. There are two IF transformer but only one IF amp. I think I'd call it two IF stages. It's basically an AA6. I guess I'll see what the local station does to me when I get it working. John |
