Old 03-19-2009, 04:38 PM
The CRT seems to be holding up OK. It actually has a better picture than a 1994 CTC177 Thomson/RCA that I just brought home.
Old 03-20-2009, 02:44 PM
Well, so much for pictures! I turned it on a while ago and now it appears that I've lost HV. When I turned it off before, I could hear a "click-click-click" coming from the horizontal sweep area. Now, I hear nothing. I have not opened it up to investigate yet and don't know if I'm going to. This thing is really in my way and I'm a little tired or replacing one thing after another.
As it happens, my favorite flea market vendor called a few minutes ago. He was at someone's house buying stuff and he said there was a working RCA XL100 solid state console there. He wasn't interested; but, thought I might be. I told him it really wasn't worth over $10. He told the lady and I could then hear her screaming in the background "TEN DOLLARS!!!! I'M NOT TAKING THAT!!!! THIS TV WORKS". Well, it may work; but, it's from the '70's and no one except a collector is going to give her ANYTHING for it! Hell, I can't sell 10 year old consoles that have cable ready tuners and remotes. Just another person that thinks because it's big and beautiful and cost $700 new; then, it should be worth a fortune!
Old 03-21-2009, 06:25 PM
I actually wound up at that estate sale where they turned down my $10 over the phone offer for the XL100. After going to the sale, I'm glad they did. The odor was enough to make one puke and it was one of those places where you felt like you needed a bath when you left. I looked at the set and it's actually newer than mine. It had the single knob varactor tuner with the power/volume and brightness knobs above the tuner knob. There were four other customer control knobs under the tuner knob. The cabinet was one of those long particleboard jobs with photofinish. I suspect the chassis was a CTC92, one of the last RCA modular chassis from around '78 or '79. The seller said she gave $125 for that set (used) back in the '90's. I told her that it was probably worth that back then; but, consoles are almost impossible to sell today, even if they are later model remote control models. I don't think she got it.
I still have not opened my XL100 to see what killed the HV.
Old 03-21-2009, 10:17 PM
I had a CTC-92 (I think that was the one) that did the click-click-click. Maybe that was the time I got a spare chassis from you? Apparently a little transformer went bad. The replacement did the same thing first time I powered up after installation. Now long gone to TV heaven. Must be something else that causes that thing to die? But your problem might be something different?
Old 03-21-2009, 11:01 PM
Mine does have audio, just no HV. Those CTC89/92 chassis use a different type of power supply where everything is derived from the flyback. My chassis still uses a regular power transformer; so, everything does not die if the horizontal circuit fails. I hope it's not something serious because I really don't want to sink much money into this set. The only reason I might be willing to go back in it is because I saw what kind of picture it can produce.
Old 03-30-2009, 08:13 PM
OK, I pulled the two ITR's in the horizontal circuit and checked them as best I could with a meter. Between the gate and cathode pins, I read 86 ohms both ways on one and 103 ohms both ways on the other. On the diode test setting, I read about .46 volts from gate to anode and when I reverse the leads and measure from cathode to anode. I used to have a homemade tester for these devices; but, don't know whatever happened to it. Do these sound like they could be bad based on my meter readings? It's been a long time since I've messed with one of these and I've almost forgotten what I knew about them. The part numbers are:
ITR101 is RCA # 141255 and crosses to an ECG310
ITR102 is RCA # 141256 and crosses to an ECG308
I think the NTE/ECG parts (which I'd rather not use anyway) are about $17 each. Unless I find something cheaper, I may let this set go. I really don't want to spend in excess of $30 on parts and still not have a working TV.
