Old 03-13-2009, 12:29 AM
That list looks correct. You can use the original RCA transistor/IC or the SGSI/TEA parts which are cheaper. As long as they are not some Chinese knock-off parts, you should be OK. I don't know about the Zener diode as I"ve never had to change one; but, I've not worked on near as many as the TV shops have. Most of the ones I've worked on were either TV shop rejects or ones given to me by individuals. The 1N4007's should work fine in the power supply. I usually order those by the 100 as they are a common failure.
