Old 02-28-2009, 06:04 PM
I just had another thought. It could be a shorted vertical IC. If you remove the IC and the set powers up with a horizontal line, the vertical IC is bad. If the IC is indeed bad, replace the electrolytic caps around the IC. There will likely be a 100 uf or a 220 uf cap that blew the IC.
