Old 02-17-2009, 01:51 AM
zenith2134's Avatar
Hmm, thats a headscratcher. Maybe the AGC control needs adjusting. Since you're running composite video through a modulator, the signal may be too 'hot' for the RF section of the Zenith. Worth a try...
Old 02-17-2009, 02:00 AM
MRX37 MRX37 is offline
Could I test that by attenuating the signal, say by running it through 100 feet of cable?
Still, the left side of the screen sometimes being brighter is more of a concern. is the video module on the main board itself, or seperate from the main board?
i'll snap a pic of the inside of the TV if it'll help.
Old 02-17-2009, 02:11 AM
zenith2134's Avatar
The 9-728 board and the 9-466 board are where you wanna be looking, as far as the video problem. Again, make sure to unsnap and reinstall ALL of those module connectors. If possible spray em all with cleaner or use an old toothbrush and isopropyl. This is standard practice whenever I open up an 80s Zenith.
You could try spooling up some coax cable to see if it attenuates the signal a lot, but IMO it'll take a heck of a lot to do so. Depends on the cable's resistance/inductance etc.
Quick and dirty test: unplug the F- connector from the set and hold it very close to the port, aor hanging out of the port, to get a snowy picture. This should help you decide if something's getting overloaded.
Old 02-17-2009, 02:26 PM
RobtWB's Avatar
RobtWB RobtWB is offline
About a year and a half ago I picked up a SE2023W set at an estate sale. It dates to September 1988. The reasons I brought it home were that it was obviously a low hour set, and it had the original rabbitt ears and bowtie still wrapped in the original packaging sticking on top of the set. The case was also flawless. No scratches, dings, dents, fingerprints etc. IIRC I paid a whole 25$ for the set.
The set has the Zenith hallmark of incredible color saturation.
Like my 1991 Panasonic 19 inch tabletop set, a simple elagant set of a quality no longer produced anywhere.
For a 20 year old set I was amazed that the set still produced such a fine picture. I was sure that I would have seen signs of aging components with this set, but not so.
I used the set with rabbitt ears as a bedroom set for a while, but now it resides in the utility room, in storage with a bunch of other sets.
Old 02-17-2009, 02:29 PM
zenith2134's Avatar
Well I got an '89 the other day and it does work but the crt is aging rapidly. I don't think it will last much longer, but judging from the inside this one saw a TON of use.
