Old 02-16-2009, 02:11 PM
Originally Posted by Jeffhs View Post
I spoke recently over the phone with a TW customer service representative, who told me that for subscribers with any level of cable service, the conversion will be handled by a box-shaped device on the roof. I live in a 12-unit apartment building; almost all the tenants, myself included, have cable (I think there may be one person here who still uses rabbit ears).
My question: How can one ATSC->NTSC converter be used with (for example) a dozen televisions, without signal-strength problems at either end of the line? I'm thinking the signal may be split among the sets by means of one or more signal splitters, of the type used with antennas serving several TVs, with an in-line amplifier to compensate for signal losses in the cable.
That box on the roof is essentially a miniaturized cable head end, several ATSC to NTSC converters inside, and each with a modulator to a (probably) VHF TV channel. Likely no pass-thru.
Originally posted by 3Guncolor:
You are 100% correct. Where I work we are already using the 8VSB over the air signal if we don't have a studio feed from the station. And you are correct we don't use $50 coverters either. There is no 8VSB signal on the cable plant it's all QAM for the digital versions of the station. We have three versions of most stations SD analog, SD digital and HD digital. In other words we are no longer using any over the air analog signals from the television stations.
You could probably just demodulate the 8VSB signal down to the MPEG bitstream, and then remodulate that into QAM onto a cable channel. So far as I know, cable uses the same MPEG 2 codecs as ATSC. No need to decode to just reencode, if they intend to keep it as HDTV. Else they do decode, downscale, then reencode if it's to be SD DTV or just go to analog NTSC.
BTW (for wa2ise): When did you move from New Jersey to Seattle? I recently looked up your amateur radio callsign on Buckmaster's callsign server and found that your license still has your Oradell, NJ address. If you're in Seattle permanently, I'd change the address on the license ASAP. As you know, the FCC has very strict rules as to licensees keeping their addresses current. After the one-year mail forwarding order expires, the FCC may not be able to find you if you are 3,000 miles from the address they have in their database. This can cause real problems the next time you renew your license, or if the FCC tries to send you any type of correspondence. In fact, failing to keep your current address on file will in itself be a violation, and could cause the Commission to deny your next renewal.
Not to worry, I'm only on a contract job in Seattle, and will be returning to Oradell, NJ soon. Just in an extended stay hotel in Seattle, and still paying taxes out of NJ. So the FCC and the IRS should be happy.
