Old 02-01-2009, 12:40 PM
maxm's Avatar
maxm maxm is offline
Surrounded by old stuff
Is this a slot loading or tray loading iMac? I've never worked on a tray loader but I've disassembled several of the later slot loading iMacs, mostly to clean out the dust. Taking off the bottom to get to the motherboard is pretty easy, but taking off the top to get to the power supply and CRT is harder, there are those awful plastic tabs all over that you will end up breaking off most of them. I think the tray loading ones are more difficult to take apart. The plastic in these is notorious for degrading due to the heat, particularly the ribbed plastic that surrounds the screen, it has been cracked on severs of the ones I've worked on. The tray loading iMacs have fans, but the slot loading ones work with convection only, though I think there were some fans made that fit around the handle.
Old 02-01-2009, 01:46 PM
karmaman's Avatar
karmaman karmaman is offline
AK Member
I replaced the flyback on a Rev. A tray-loader. Managed to do it without cracking the plastic but I came mighty close. I'd suspect caps because these things run HOT!
Also, I think the tray loaders are easier to take apart than the slot loaders. Getting to the PAV in my Rev. E slot-loader is a pain.
