  #32
Old 01-29-2009, 12:55 PM
Ed in Tx's Avatar
Ed in Tx Ed in Tx is offline
Zenith Walton My 1st TV
Originally Posted by piece-it pete View Post
Something to consider, if a tv is set up wrong it will look bad.
Pete
I believe that's probably a main reason so many have such negative opinions; not set up properly, using the factory presets and not properly setting the backlight, contrast, brightness, color, and gray scale properly, and not turning OFF most if not all of the video "enhancing" functions which usually seem to degrade the picture more when enabled. One that does work quite well in my Sony is the Advanced Contrast Enhancer set to Low. Really brings out the black levels without crushing the details. I watched CRT sets for 57 years, last summer retired a 30" NEC CT-3000 TV that I bought in 1988 that has a Toshiba tube in it, and I can say PROPERLY SET UP my Sony LCD meets and exceeds all my expectations. It has excellent black levels that blend into the black cabinet. Colors are very accurate. No discernable blurring, watched a Mavericks basketball game last night excellent motion handling. Viewing angle is fine for any angle it will be viewed at in my living room. I usually sit generally in FRONT of a TV if I am watching it. As far as LCDs looking worse on SD than plasmas, that has to do with the A-D processing not the type of panel it uses. Some sets are much better upscaling SD video than others, regardless of the type of panel.
