Old 01-18-2009, 03:35 AM
waltchan waltchan is offline
Could be the sensor lamp or sticky mechanism?
Originally Posted by radiotvnut View Post
OK, I've torn into the subject VCR and need some help. The actual power switch is not broken. It's just the lever that activates the switch that is broken; but, that's the least of my worries at the moment. My two biggest problems are: 1. It's full of roach poop and 2. All of the function keys are locked for the exception of fast forward, stop, and eject. The other keys will not depress with a tape in or out. FF works OK and it shuts off at the end of the tape.
Check to see if the sensor lamp inside the cassette compartment lights on when powering on the unit. If it does not and you see no light, then the VCR will not function at all and cannot be depressed, unless a new sensor lamp light is installed place.
Another problem could be sticky mechanism underneath the press buttons, causing them to lock out. There could be one gear that is stuck and not free, or the spring had popped out or bent that failed to catch the gear. You will need to remove the top cover and cassette tray loader for inspection.
Roach poops do not destroy the mechanism, but they may destroy the copper trace lines underneath the unit. Check to see if the main board located underneath the unit is still in good condition. Use a small vacuum cleaner with a small brush to suck out all the roach poop.
Let us know how it goes? I'm very familiar with this chassis, so I know most of the problem in and out. I used to own a RCA VDT625 before way back in 2002 before I donated to Goodwill. I now own a Panasonic PV-1600, which is identical to your RCA VDT-625, that is in like new, mint condition with all its accessories (box, manual, cover, pause remote).
