How much crap is in there? That sh*t is very stubborn, it will be very hard to remove without damaging anything. Make sure there aren't any roaches or eggs in there, you'll get roaches. Sounds like this machine might be beyond repair if they pooped too much in there. If you have one of those little metal stems from a switch you can drill a small pilot hole into where the stem goes on the switch. Then find a screw that will screw into the end of the metal stem. Do that first and thread the soft aluminum shaft. Then cut the head of the screw off and make it a little longer than the shaft. Install the headless screw with pliers and leave about a quarter inch sticking out. Then screw on the aluminum shaft and it will be good as new. I did this to my Zenith Allegro " The Wedge" stereo system about ten years ago and it is still fine. I can send a pic if you want. As for the buttons, you will just have to follow the mechanism and try to find the jam.
