Old 01-11-2009, 01:27 AM
jfrog1983 jfrog1983 is offline
I bet that "EEEE" problem was the glue problem those older Mitsu VCR's seem to have, shorting out the circuit board parts making the unit die.
I am gonna start messing with changing video head drums on my own, I have like 2 VCR's now that need a new upper cylinder, that video concepts (Mitsubishi HS-400UR or HS-410UR), and a Toshiba I found today.
Old 01-11-2009, 02:13 AM
waltchan waltchan is offline
Glad I don't have any early Mitsubishi VCRs. I just cannot recommend early Mitsubishi VCRs for the super long run.
Replacing the upper cylinder requires a little star screwdriver to remove the shaft in the video head drum. Sometimes, soldering is required to remove a circuit board on top of the upper cylinder. Not sure about Mitsubishi, but early Panasonic VCRs made before 1982 have the easiest video head to change, in my opinion.
Old 01-11-2009, 10:13 AM
Ed in Tx's Avatar
Ed in Tx Ed in Tx is offline
Zenith Walton My 1st TV
Problem I almost always ran into on the Panasonic-made machines was the new upper cylinder, even the OE Matshushita replacements, not fitting snugly to the hub, making the upper cylinder a bit eccentric unless you got real lucky. This would result in a lot of flutter in the linear audio on playback. I resolved that by making a test tape at SLP with color bars and a 3kHz tone recorded on it, on a machine that exhibited very low wow and flutter. I would then play that tape back with a wow/flutter meter plugged into the VCR audio output, and with the uper cylinder screws barely snug, with a plastic screwdriver handle very lightly tap the upper edge of the cylinder as it was running. Yes it sounds crude, but it works! After a few taps the upper cylinder would land at a position where the flutter would drop to less than .1% which is very good, and tighten the screws down at that point. This same tape with the 3kHz tone and W/F meter was a good diagnostic for a bad take-up clutch that plagued those Pannys in those days. The clutch would get sticky and worn, and make very rough almost vibrating takeup torque, which made higher than usual flutter so bad sometimes the linear audio would sound garbled. With the test tape and the W/F meter I could catch those clutches as they were beginning to get sticky and fail even if the unit wasn't in for that particular problem, go ahead and replace while on the bench: "Preventive maintenance".
Old 01-11-2009, 10:42 AM
I didn't know you had to remove the whole shaft. Ed was telling me all you have to do is desolder, and remove the 2 screws on top of the drum, and maybe use a hairdryer if it doesn't come off easily.
Luckily none of my Panasonic VCR's need new drums, even the PV-1545 that was given to me from the previous owner that bought the thing new in 1984.
Now, the power supplies on these are a different story, the caps are gonna need replacing soon.
