Doug,
Can you get to the bottom of the board in the tuner? With one good tuner and one bad, you could troubleshoot perhaps to the bad component. Sams 1312, Folder 3A has the tuner with all of the voltages and resistance checks, and even a picture of the board - apparently the epoxy conformal coating came with a later production. Looking at the schematic for the tuner, AGC voltage is applied to the RF Amp (a 121-787 dual gate MOSFET) via a 100K resistor, and tied via a voltage divider to the source lead of the same MOSFET. There are only 4-5 components total in the RF AGC circuit in the 175-1503, all located in the smaller of the two cavities. Hope this helps - I have only three Zenith tuners - two VCR Cheers,
