Old 12-14-2008, 01:40 PM
Kiwick's Avatar
Kiwick Kiwick is offline
slave to 3 equines
Originally Posted by Electrohome View Post
Yes, that's a 1973-74 Philips 23-inch solid-state console I picked here in North Bay in that 1970's style low-boy cabinet with speakers on each side and a continuos-tune UHF tuner. The set also has a 23-inch Delta-Gun CRT as well.
Is this set based on the K9 chassis like the one in the pic? this chassis, along with the inline CRT version K11, is a real masterpiece
Old 12-14-2008, 02:07 PM
Electrohome Electrohome is offline
1973-74 Philips may have similiar chassis-has Delta-Gun CRT
Hello, I would have to take the back off of my Philips 1973-74 23-inch console to find out. I currently have that TV in storage right now. I thnk it may be similiar. Allso, does yours have a delta-gun CRT too, just curious. About what year is your set-thanks. Mine fully works and I can get channel 2 with no antenna on it. It's got a delta-gun CRT. It came from an older couple here in North Bay.
Old 12-14-2008, 04:23 PM
About 19 or so years ago, my wife and I went to see a movie. There is an electronic shop next door to the theater and when we parked I walked through the shop's parking lot. They had tossed out a nice complete little Porta Color. Of course I picked it up and put it in the car. I forget what movie was playing because all I could think of during the show was that little TV and what was wrong with it.
Guess what? When I got home and took the back off all that was wrong with it was a bad on/off switch and it worked perfectly!! I sold it the next day for $100!
julian
Old 12-14-2008, 07:46 PM
Kiwick's Avatar
slave to 3 equines
I have two K9 sets, one from 1973 the other from 1975. the K9 chassis was made from 1972 to about 1976
They all had shallow 110 degree delta gun CRTs, if it has a 90 degree CRT then it's not a K9.
In 1974 the K9 was modified into the K11 chassis which was intended to drive Philips' new 20AX inline CRT, the signal and power supply boards are exactly the same as in K9 sets.
Old 12-16-2008, 12:06 PM
zenith2134's Avatar
1966 Portacolor
Here's mine with a new 11SP22 installed (thanks, Dave A.)
I use it here and there, but with all this talk of energy concern I feel kinda bad since it uses 200 watts and throws a massive amount of heat.
Its almost as old as the 'boat' in my avatar and the ride is just as rough
Got the same exact one as Findm Keepm it seems. Trust me, the pic on this one is better than my photos show-I can't take a picture to save my life
Built in good ol' Electronics Park, Syracuse, NY.
Keep em comin', fellas!
Old 12-16-2008, 01:02 PM
Use it in the winter time. That way you can kill two birds with one stone. Watch tv and heat your pad! Makes a good space heater.
Old 12-16-2008, 05:03 PM
Findm-Keepm's Avatar
Followin' the Rules...
Your picture taking abilities are a lot better than mine! And your set looks better too!!
Cheers,
Brian
USN RET 22YRS (Avionics/Cal)
Old 12-16-2008, 06:56 PM
My dad was kinda big on "gadgets"-He got one in late '65 or early '66 to replace an AWFUL Sears mini-console that-I SWEAR-Hated us. Anyhow, the little Porta-Potty was on 18/7 for something like 8 years, when we got a 17" Trinitron. I don't remember it giving any trouble, we got a REAL trooper w/that set. Guess that's another reason I have such a soft spot in my heart for 'em...But yeah, I remember it would get hot as a firecracker w/all those tubes a-glowin' in it...
Old 12-16-2008, 07:00 PM
Hey zenith2134, that is one sharp lookin' Porta-Color you got yourself there! I give it the thumbs up too!
Old 12-19-2008, 03:57 PM
tritwi's Avatar
tritwi tritwi is offline
zenith mad
Portacolor
This is my original porta color made by Ge. Curiously it doesn't show the name "porta color" anyway.
Old 12-19-2008, 03:59 PM
tritwi's Avatar
zenith mad
forgot the picture...
picture of my porta color ge
Old 12-19-2008, 09:06 PM
dtuomi's Avatar
dtuomi dtuomi is offline
That's a nice picture, tritwi. Is that portacolor an NTSC one? I think someone made a Portcolor that was PAL or Simple PAL or something.
David
Old 12-24-2008, 12:09 PM
tritwi's Avatar
zenith mad
kuba portacolor
Hi David, yes the Ge portacolor is an original NTSC model. I fed it with a multistandard VCR playing an NTSC tape. The picture is quite good! This picture shows my other portacolor (the european model you mention). It is a simple PAL set and it shares very little of its ciruitry with the original portacolor despite the fact both sets employ the same type of picture tube and have a very similar look.
Old 12-24-2008, 12:29 PM
tritwi's Avatar
zenith mad
other european portacolor
There was another set using the same chassis and tube of the european kuba porta color, this was the telefunken telecolor (left picture). It just had a more modern look.
Old 12-24-2008, 01:04 PM
zenith2134's Avatar
It's amazing to see how many variations of the Portacolor were produced. Tons!
I like your PAL pal.
