Old 12-18-2008, 10:56 AM
ohohyodafarted's Avatar
Bob Galanter
As for the art work, I would place the old part on a large flat bed scanner at Kinkos. Then i would have it printed in full color on a color printer onto clear acetate film and sandwich it between two pieces of thin glass cut to the exact shape and dimensions as the original glass.
The other alternative if you are willing to spend the moeny, is to take the newly cut glass to a silk screener along with the old part. A silk screener can photo the old art work on the old glass and print it on the new glass in multiple colors. This would cost about $75 per color, so I would vote for the Kinkos method because the value of the set is not that great.
Good Luck!
ME http://AntiqueTvGuy.com
Old 12-18-2008, 02:44 PM
Once, I took a radio panel into Kinko's for scanning. They refused to let me put it on their scanner bed. Nothing allowed there but paper or equivalent. Risk of scratching the glass, I suppose.
Phil
Old 12-19-2008, 03:37 AM
yagosaga's Avatar
yagosaga yagosaga is offline
VK Member
Hi folks,
I will probably have somebody who is willing to make a replica of the front glass. The tv set is General Electric model 806.
Is somebody here interested in getting a replica, too?
It might be cheaper for us all to produce some more front glasses than only a unique replica.
Kind regards,
Eckhard
Old 12-20-2008, 02:36 AM
cbenham's Avatar
cbenham cbenham is offline
Does this look like the same cabinet and glass as your 806 set? The tube diagram inside is marked model C2505 or C2506. The CRT was a 10BP4.
If so, you can have both pieces or just the glass for postage from zip 19390.
They are from a parted out set. The green back paint is chipped away near the top as shown but the glass is not broken.
Cliff
Old 12-20-2008, 10:36 AM
Reece's Avatar
Reece Reece is offline
I think once you have new glass, cut some pieces of tubing to the proper length to makes stops that slip over the knob bolts for the two fixing knobs at the top of the glass, and put felt washers under the knobs. Adjust the length of the tubing so that the knobs can be tightened just enough but not overtightend.
Reece
Reece
Old 12-20-2008, 11:02 AM
Tony V's Avatar
Tony V Tony V is offline
Hi Cliff,
If no one else speaks up, i would like to have the cabinet and glass. Just let me know.
Thanks,
Tony
Old 12-20-2008, 07:32 PM
Kiwick's Avatar
Kiwick Kiwick is offline
slave to 3 equines
I think you can't just use regular glass or plexiglass here for safety reasons as they're too weak to contain an implosion, you'll need laminated glass.
Old 12-20-2008, 07:59 PM
jeyurkon's Avatar
jeyurkon jeyurkon is offline
Good point. How about Lexan®? It should be pretty tough.
John Y.
Old 12-20-2008, 09:06 PM
Dave S's Avatar
Dave S Dave S is offline
<-- Me and my "first" TV
I'm all in favor of being safe - and of not having my face cut to ribbons by shards of flying glass - but I suspect you may be overestimating the force of an implosion. Also not a very likely occurrence. I'm going to guess that although safety glass or lexan would be the best choice, nearly any old piece of glass would likely contain the debris from an implosion of a 10" tube. This would be a good project for "Mythbusters" (or an adventurous AK person who likes to blow stuff up) to test out!
--Dave
Old 12-20-2008, 11:07 PM
jeyurkon's Avatar
--Dave
Neither of the two that myself and a friend tried to implode in our youth were very interesting. Some of the stories must be exaggerated.
It would be interesting for Mythbusters. Hopefully they would be CRTs that Hawkeye wouldn't accept for rebuild.
Here's some anecdotal info.
http://www.repairfaq.org/sam/crtfaq.htm#crtcir
John Y.
Old 12-20-2008, 11:18 PM
At about the time GE was making this set, Philco, Admiral and others were using plastic. Consider that if you were to pick up a 10BP4 and try to throw it through a sheet of plexiglass I really don't know if you could do it. I had to replace the one on a '50 Philco as some chemical had left spots etched in it. A replacement from the glass company (some sort of plexiglass, or whatever they sell) was cheap and easy to obtain. I suspect that plain window glass wouldn't really be safe but thicker or laminated glass should be fine.
John, that site you link to is quite impressive!
Old 12-21-2008, 12:19 PM
mbates14 mbates14 is offline
I would use plexi with a printed vinyl emblem behind it. that way if the plastic gets scratched or damaged, its easily replacable.
Old 12-21-2008, 07:02 PM
Kiwick's Avatar
slave to 3 equines
--Dave
Each implosion is a story of its own, sometimes all the glass will just be sucked into a heap inside the set but but sometimes it's ejected with extreme violence and in the worst case scenario the neck/electron gun assembly will be propelled towards the screen at very high speeds and if this happens you need something really tough to stop it.
Keep in mind that plain glass may be smashed by the implosion's shockwave even before the glass shards start to scatter outward
also, some early B/W CRTs are made of thin, weak glass and are prone to spontaneous implosion.
Old 01-19-2010, 05:22 AM
yagosaga's Avatar
VK Member
Hello,
in the last days, I have picked the GE 806 tv set which was waiting for repair since months.
In the mains unit, one 5 Ohm resistor before the rectifiers was burned, I replaced it. The 19BG6 was also weak, I replaced it. One wax capacitor was leaky, I unsoldered one end and added a new one. After that, I reformed the electrolytics and switchet the set on. It showed a dim raster. Sound it working well.
The original 10BP4 was very weak and came with a brightener. I have rejuvenated the CRT and removed the brightener. Currently I am working with the bad picture tube, but when works are done, I want to replace it. I have got a good 10BP4 (0.4 ma) and a good 10FP4 (0.9 ma). Which picure tube might be the better selection for replacing?
Kind regards,
Eckhard
Old 01-20-2010, 10:58 PM
I'm pretty sure the original used a 10FP4 so I would go with that. It's a lot brighter too
