Old 12-16-2008, 08:49 PM
Ex-Philco
You need both chassis and the yoke for all the voltages to make sense. It's not much trouble and you can be fooled by the missing half. I would not recommend running the sweep chassis without the yoke. That will throw the boost voltage off as well.
Check the resistance of the height and lin controls and the resistors in series. Check for a high resistance from the height control tabs to ground. That should read open. Sometimes grit will get in the front of the control and load down the voltages slightly.
The discharge cap off the oscillator plate is another suspect.
What is the chassis number?
