Old 12-08-2008, 01:25 PM
radotvguy radotvguy is offline
mike g
I am helping out a friend trying to get this up and running . Its a model 22BU4302. Have not found a chassis number yet . It has a 21zp4a picture tube . Here is the tube layout in this set .
12b4a (vertical output)
12au7 (vertical osc)
6al5 (phase comp)
12au7 (horz osc)
6bq6gt (horz output)
1b3gt (hv rectifier)
6ax4 (damper)
6cb6 (if amp)
6x8 (osc mix )
6bz7 ((rf amp)
6au6 (video amp)
6v6gt (aud)
6t8 (agc/fm det)
6cs6 (sync sep)
6aq5
I am trying to obtain a schematic however have not found one yet . Found the horizontal output tube bad , replaced that as well as the damper and rectifier . Powered it up breifly on my variac and had high voltage and sound , however i had just a white horizontal line across the screen . Then replaced the electrolytics ,wax caps and bumble bee caps . I used orange drops there . I only worked on the chassis on right side which is the vertical, horizontal and high voltage . Put the chassis back in and got the same issue . Checked the pots(vertical height and lin, which were definitly dirty, sprayed them with some de-oxit and then they seemed to read ok in circuit . Still have same issue except the horizontal line opens up a but more when height is set to max . Seems to be a straight forward set, however my next step is obtaining a shematic and i guess check all resisters , then go from there . Can anyone chime in and give me any advice .
thanks
Mike
