Old 12-07-2008, 10:48 PM
mbates14 mbates14 is offline
Ive done this before. using old viewfinders and with the same lenses made a mini-CRT projector.
it will work ok, if you use a NTSC Decoder circuit. youll get a R, G, B, and H/V sync. that you can mix together and get the composite sync needed to drive the CRT view finders. BUT on some cases you may need those H/V sync lines depending on the viewfinder. Cliff Benham will be able to clue you in on where to get an NTSC decoder module. (as you need this to make a homebrew color-wheel system).
your next problem is convergence. youll never have convergence unless you design your own circuit. In my case, i used a rather large analog convergence board, and took the H/V sync gate pulses into the board, and outputted this into makeshift coils wrapped around the current yokes.
it worked ok, but you could never get it perfect. (obviously).
