The PLAN
THESE ANTENNA PLANS ARE THE WORK OF PITMAN2 AT THE LUMENLAB.COM FORUMS.
I would just link you guys to the page, but Lumenlab requires registration just to view the forums. Again, I did NOT create these plans, kudos to pitman2. The antenna is pretty much a reflector (carboard wrapped in aluminum) with four "V"s made of coat hanger wire attached to a balun. This picture, posted by Allen from the Lumenlab.com forums, will show you guys how the antenna looks far better than I can. ![]() The above picture was NOT created by me. It was posted by Allen of the Lumenlab.com forums. The plan is to build four of these as one unit and wire them up to two baluns, then backwards through a splitter, and then into the converter box. Here is a picture of such a beast, as posted by Dan of the lumenlab.com forums: ![]() Thoughts? |
