Old 11-06-2008, 01:18 PM
MRX37 MRX37 is offline
You can add JVC 2004 sets to the junk pile...
Found a nice JVC TV, made in 2004. The CRT is nearly dead. Even with the G2 voltage set as high as it'll go and the brightness/contrast maxed out, the picture is still dim, has a blue tint, and the convergence is already failing.
Looks like Zenith's bad CRT formula spread to JVC...
Old 11-06-2008, 01:32 PM
waltchan waltchan is offline
The CRT screen is made by Zenith? I thought most JVCs use Panasonic picture tubes.
Old 11-06-2008, 01:38 PM
zenith2134's Avatar
In 2004? Doubt it would actually say Zenith on it. And even if it did, it would either say 'made in Malaysia' or 'made in South Korea' somewhere on the bell. JVC! NIVICO! I used to be a big fan.
Hey MRX, looks like you're about to break 1500 posts!
Old 11-06-2008, 01:52 PM
freakaftr8's Avatar
Convergence freak!
What MRX37 was saying is that Zenith CRT's of the mid 90's up and the JVC CRT's are both junk. I dont think there were Zenith tubes in the JVC units (at least as far as I know of).
Old 11-06-2008, 02:31 PM
No, the CRT has a JVC label on it.
What's funny is that a similar JVC model from 2001 still has half decent CRT in it, also with a JVC label...
Old 11-06-2008, 04:41 PM
I had a JVC of the same vintage with a bad CRT. The set came to me with some open surface mount resistors on the CRT neck board. I hung on to the set and eventually found a little older JVC with a burnt up chassis that used the same tube. I did a tube swap and all was well. BTW, my JVC was very cheap made.
I've got a couple 27" JVC's from the early to mid '90's that I have not even opened yet. They should be OK since they are from the '90's.
Old 11-06-2008, 05:13 PM
freakaftr8's Avatar
Convergence freak!
Typically when the crt goes south it probably starts to intermittantly short. I had a Hitachi PC monitor do the same.. It eventually took out the flyback!
Old 11-06-2008, 06:10 PM
Nakdoc Nakdoc is offline
nakamichi spoken here
JVC has 2 lines, the cheap stuff and the good stuff. We are an ASC for JVC and the only tube we've had repeat problems with are flat 32" sets.
A stereo can work and it can play.
SOTA Sapphire, Lustre arm, AKG mc
Yamaha C85 , C1
Carver TX-11a
Kenwood L-07MmkII , Yamaha B1 + UC1
DCM Time Windows ADS 200 IMF TLS80
Revox B77 Nak 680 pioneer CLD97
Old 11-06-2008, 06:23 PM
The one I had was a 27" "D series" set.
Old 11-09-2008, 06:22 AM
Greg B. Greg B. is offline
AK Donor
I bought one of those in 2001. I was a little suspicious because they replaced a previous line and had a lower price point while offering more features. But it worked well for me except for an annoying buzz from one of the speakers, fixed by opening it up and tightening one of the mounting screws. It is now mostly retired and in the basement since I bought a big screen a couple of years ago. Here's what it looks like (not my set, but identical):
Pioneer SX-3900, SX-3800, SX-3600, SX-880, PL-S40, PL-2, H-R 100
Akai GXC-710D, AP-206
Yamaha P-200
Marantz SD-3030
PSB Mod. 40 MkII
