Old 10-08-2008, 10:14 AM
sampson159's Avatar
sampson159
all tubes check good and operate properly in another set.agc adjustment does nothing.found a bad resistor in the video circuit and replaced to no avail.no sound or video unless that 6ka8 is out of the socket.
Old 10-08-2008, 06:25 PM
Chad Hauris's Avatar
I have seen lots of cases of bad connections/bad solder joints in RCA's along with burned wiring...usually results in power supply voltages getting removed from a stage causing trouble. I'd check all the power supply voltage outputs and then check voltages at the tube sockets....sometimes heat from a tube causes cracking at the socket pins and it can be hard to detect the problem.
Chad Hauris
