Old 09-30-2008, 07:05 AM
JB5pro JB5pro is offline
Nice & rare RCA HEC CTC-17 goes in 12 hours
Item number: 200257073633
While it's a base model I think the control set up is a nice difference from most others. I wonder if the channel indicator drum would melt having the bulb's heat going straight up into it?
Old 09-30-2008, 09:23 PM
freakaftr8's Avatar
Convergence freak!
Well I am surprised nobody else bidded on the set... I won it. This should make for a nice wintertime project. It deffinatly is a CTC 17 and surprised to see no cataracts.. It's gotta have a replaced tube, and probably had some good long use to it as well. The question I have is the guy says it's a 25" screen.. If that in fact is a CTC 17, thought they only had 23" screens around 1966 or so.
Can you guys believe that this is going to by my 3rd combo unit! This one, my 66 Magnavox color remote unit , and my 65 Airline (magnavox) roundie unit.
The only other set I have is the 67 Zenith color daily watcher.
Old 09-30-2008, 09:59 PM
It's a very attractive set. There is info somewhere in here about the issue of 25" claims of 23" sets. I think back before the early '70's makers were allowed to lie about the screen size claiming the sets were 25" when they were actually 23". Like most things the masses are told it was accepted for many years and then I guess some smart attorney got involved to make big business tell the truth on something rather insignificant compared to all the other truths they are never going to admit.
Old 09-30-2008, 10:27 PM
freakaftr8's Avatar
Convergence freak!
Ah, got it. I thought something was strange there.
Old 10-01-2008, 02:10 AM
The CRT size issue is the viewable/lit area versus the external size/diameter of the CRT glass itself. All of the so-called 21-inch round color CRTs have a 19-inch diagonal/diameter viewable picture. Computer CRT monitors in the USA were sold by the viewable area size as well (whether required by law or not) until somewhere around 1996-1997, then they started using the deceptive CRT-size numbers as in earlier days for TV sets. 16-inch monitors then became "17-inch", 13s became 14s and so on, with no increase in viewable area from the previous year's models.
Old 10-01-2008, 03:26 AM
freakaftr8's Avatar
Convergence freak!
Yeah I read up somewhere about that. The whole (21" 19" viewable) thing. I was sure that in the 60's there were no 25" viewable CRT's..
Old 10-01-2008, 11:42 AM
Maybe that's the diagonal size of the 4 by 3 NTSC aspect ratio rectangle, had it not been truncated by the edges of the CRT... Back then, they used to play games with audio amplifier power ratings too.
Old 10-02-2008, 05:58 AM
Funny how history keeps repeating itself as if nobody wants to or can learn from the distant or near past.
Old 10-11-2008, 11:59 AM
freakaftr8's Avatar
Convergence freak!
Well my brother picked this set up for me last night and brought it up to Sacramento for me. When it got here the neck of the CRT is busted... Bummer. The CRT was perfect too and no cataracts.
The only thing going through my mind is that the CRT could have been bad to begin with. Anyone have a 25AP22? lol
Old 10-17-2008, 06:14 PM
freakaftr8's Avatar
Convergence freak!
Well I have a 25XP22 CRT on order, I pulled the HOT and fired her up on the variac, around 70v got sound, after full power and a day of running, the caps do not seem to be heating up. Just as a measure I will check the esr readings this weekend.
Old 10-18-2008, 11:48 AM
Robert Grant's Avatar
Robert Grant Robert Grant is offline
Yes, the viewable vs. total screen size issue.
As early as the early 1960's, many catalogs would state the viewable picture in square inches, either alone, or with the "total size" diagonal.
Sometime in the early 1970's, it became law (FTC, I think) that manufacturers stop quoting a total size and use the viewable instead, so 25" color TVs suddenly became 23". That's why a 23VALP22 CRT is a replacement for a 25XP22, and many of the CRTs of the mid to late 1970's have a "V" as the first letter after the beginning numerals of their type.
This action did not apply in Canada, which is why the cartons for TV sets in this era carry the hilarious oxymoron "25 INCH COLOR TV, 26 INCH IN CANADA"
Now (I guess the regulation was lifted somewhere along the line), you see the same thing, e.g. "46 inch class Plasma HDTV.....actual diagonal measure 45.03 inches".
Old 10-18-2008, 05:02 PM
Old 10-18-2008, 06:39 PM
I hate deception and gray-area shenanigans... Not a person on the planet would ever care about the glass size of a display they were choosing or watching. Every one, every time, cares about the size of the picture they are going to get. Describing the size of the CRT outside diameter (or diagonal measurement of a rectangular tube) was just plain sleazy behavior to make people think they were getting something bigger than they were, from the very first day it was done, or certainly it was as soon as a CRT bigger than the smallest on the market was advertised by measuirng its glass.
Old 10-18-2008, 06:48 PM
It also never applied to computer monitors, so a 19" TV would be a 20" monitor. It's kind of silly really. As long as everyone measures them the same way, what difference does it make?
As I mentioned in post #5 above, it definitely happened with computer and other monitors. In the late 80's to early 90's, I installed plenty of 13" and 25" Sony color monitors, for example. They had 13" and 25" viewable rasters. Later replacements for those had the glass-size number in their description, such as the PVM1341 or PVM1351 monitors replaced by PVM14N2 and PVM14M6, though all had the same CRT size. A Sony PVM2950 has a CRT (and a viewable area) only two inches bigger than the older PVM2530, not four inches bigger. Maybe only Sony was honest for a time period and all other monitor makers used the glass-size numbers; I haven't measured any other older monitors.
Old 10-18-2008, 06:55 PM
I hate deception and gray-area shenanigans... Not a person on the planet would ever care about the glass size of a display they were choosing or watching. Describing the size of the CRT outside diameter (or diagonal measurement of a rectangular tube) was just plain sleazy behavior to make people think they were getting something bigger
At the David Sarnoff Research Center (what used to be RCA Labs), in the company library, they had on display the first shadowmask color CRT ever made (a lab prototype) and it was about 11 inches round (a roundie) but the viewable area was a small rectangle in the center, about 4 inches diagional. Imagine the fun salesmen would have had if that was a production CRT! Not a production model, but it was something they threw together for a FCC demo (RCA was petitioning the FCC to reconsider the selection of the CBS color wheel scheme for color TV, back around 1953). The guys at RCA thought of it as a stopgap kludge (what, shadowmask and 3 guns, and 75% of the electrons are thrown away!), but they wanted to demo that a single color CRT was possible, and that you didn't have to do the B&W CRT with a color wheel, (which pretty much mandates sequential color fields) to get color images. Well, that stopgap lasted about 50 years...
