The condition you see is called fold-over. The bottom part of the vertical scan has folded over on itself causing the black bottom and bright band. Its usually caused by leaky or shorted capacitors, occasionally a resistor that has gone up in value. Look in both the vertical oscillator and output section.
You would have to pull out the cap to test it on an ohm meter. You would also need an ohm meter that put out a high enough current to test the cap for leakage. Since you have to pull it - just replace it.
Trust me on this. Replace the coupling caps in this set and most if not all of your troubles will disappear. I wouldn't even bother to waste your time further. The set basically works - so why not just restore the chassis completely? I don't understand why you might want to have to keep servicing it in the future when another problem pops up from leaving original parts in.
