Ahhhh I was checking those resistances earlier. They seemed alright but I did not check from 7-6 or the nine one. So I will do this.
And this has been driving me nuts. On the schematic you sent me v-2 is on the left and v1 is on the right. But on the back of the TV in its tube diagram V1 is on the left and v2 on the right. SO I checked the tubes and surley enough they were as the schematic you sent me v2 left v1 right. BUt on the back of the tv (Which had to of been right for this model) It is reversed. SO if the tv's original cover does not lie. These tubes are reversed. And need switching. I will put a picture of the tv's diagram momentarily. Also one of these tubes was a weak one. And if they really are in reverse maybe it is because the heater voltages were different causing earlier melt down. Hmmmm... no motorboat noises. But I will listen harder. Haha I also thought the brightness might be the cause. So I fiddled with all the controls and it just wouldn't work.(Bummer) But cleaning it sounds like a good idea. It was very dusty. I'll blow it out tomorrow when I am checking the coil resistances Pictures in 2 minutes |
