Old 09-22-2008, 10:55 PM
It probably has a defective vertical output IC and probably the fusible resistor in the B+ line to the IC is open. I've seen electrolytic caps in the vertical circuit fail and take out the IC; so, you'll probably be doing the right thing by changing the caps. You can probably find a data sheet for the vertical IC online. The datasheet should tell you where the B+ enters the IC.
