Alright I have 2 or possibly more 6a2 diodes. I think they are rated at 6amps 200 volts. And I know I built a 250 volt power supply from them. Would this be sufficient as a replacement. Cause from what I read the selenium are much larger than the silicon ones. So maybe these two guys would work? They are about 1 cm long and .7 cm in diameter.
Like I said I have no money so I wanna do anything I can with what I've got. (.91 cm x .91 cm actually)
And If I do have more than one can I double them up or put them in series to increase the voltage they can handle? I know it can be done with a cap
And one more question. The caps in this TV do you think there full of PBCs. Or is there no doubt they are
