Old 09-01-2008, 12:05 PM
sampson159's Avatar
sampson159
the rings are for purity.it must be set first.use a red only screen for this adjustment.the 3 controls on the crt neck are for center convergance only.the smaller controls are for top.bottom,left side,right side.etc.steps are as follows-
1.-red screen -purity
2.gray scale-service line,adjust rgb to a white line,even luminance.
3.center convergance-red and green,blue vertical and horizontal(dial on purity assembly)
4.top -small controls-marked-red,green,blue
5. bottom-same
6.left side-same
7.right side-same
once purity is set and center is aligned,it should be close enough for viewing.no reason why a delta gun cant be near perfect with some tweaking.dont drive yourself insane trying get it perfect-not going to happen.it can be very close and deliver a fine picture.
use an alignment tool(diddle stick) for the sides.i have an xl100 from 1974 and it came out very well. good luck!
