Old 08-27-2008, 11:32 PM
ha1156w's Avatar
ha1156w ha1156w is offline
Zenith 17z22q odd scanning
Okay, I finally rounded up some tubes for my long-neglected Zenith 17Z22Q SC200 console. Brought it up slowly on the Variac and got the oddest result. I'd say it had vertical or horizontal collapse, but the line is static DIAGONAL! The yoke doesn't look disturbed. Yeah, it's complete recap time.....I relent. No audio (so no IF) and changing the channel doesn't create any difference whatsoever in the pattern so obviously no RF either. Anybody run across something this bizarre?
Old 08-28-2008, 10:49 AM
electroking's Avatar
a- v- karma member
Wild guess: yoke is really undisturbed, but it has an internal short that allows
the vertical sweep signal to leak into the horizontal coils.
Old 08-28-2008, 11:38 PM
ha1156w's Avatar
Oh boy....well, if that's the case, how hard is it to get another yoke for this chassis? Is there a universal type replacement for this tube?
Thanks!
Old 08-29-2008, 04:09 AM
It is quite a interesting problem , I have not seen that one before .
However , I has a similar problem with my 1954 Crosley . with the Ion trap , but it was way way darker .
Im going to agree with electoking , and also say a shorted yoke .
It would most likely have keystone , but also appears to have a dead vertical oscillator or output section .
Old televisions will do almost anything when a recap is due , and it may not need a new yoke .
I would start with the caps , and go from there .
The CRT looks to be nice and bright , which makes it a bonus for restoring .
Im not sure about the availability of a NOS or used yoke , but someone will probably chime in that knows more about that than I do .
Best of luck with it .
Old 08-29-2008, 11:03 AM
edison64's Avatar
edison64 edison64 is offline
THE A-1 WIRELESS MAN
Location: NW INDIANA THE MAPLE CITY LA PORTE (GO SLICERS)
Ok for whats worth, here are my 2 cents, Back in the 70s ,we had a local tv repair shop, the guy had a booming business, selling new color sets. He did verry little repair work on old BW sets and old color sets. The old sets some how couldnt be repaired. if the customer, wouldnt buy a new set, the guy would sabotage the old one one of his favorite tricks was to take a small straight pin, like for sewing, clip off the head, and....... push it in the tight windings of the yolk, shorting it out. what an ahole I had a philco that he worked?? on, looked very similar to your pix.
RCA VICTOR and its dealers bring you......
Old 08-29-2008, 11:40 AM
If it needs a yoke, I wouldn't worry too much. One of us might have it, and if not Moyers might.
Old 08-29-2008, 01:06 PM
Konrad Schiecke Konrad Schiecke is offline
AK Member
Based on my experience working at Zenith your problem is definitely the deflection yoke. Zenith had lots of trouble with a yoke vendor and thousands of yokes were being returned each week. The problem was eventually solved by going in at the vendor and showing him how to properly wind a yoke. The two main defect simptoms were the diagonal pattern and a keystone pattern.
Later on when color was blooming we (Zenith) went into our own manufacturing of yokes.
konrad
Old 08-30-2008, 08:04 PM
ha1156w's Avatar
*sigh*. Well in preparation, what number yoke should I ask Moyers for?
Thanks for all your help!
Old 08-30-2008, 10:10 PM
For what it's worth, the Sams is 343-18. I looked but I don't have it. Way back in the attic I have a couple Zenith chassis' but if I wrote down the numbers I lost the note. If you really get stumped I'll go digging.
