Old 08-24-2008, 08:14 PM
mbates14 mbates14 is offline
Found an old RCA for $5. NEED SERIOUS ATTENTION tho.
I picked up an RCA. Im not even sure what it is. It is in very very poor shape. has a broken pot/missing knob, the face is panted, and the wood around the speaker is cracked/missing as noted.
it also looks jerry-rigged on the antenna or something. I dont know what is really supposed to be there. Also im not a wood worker, I was wondering can anything be done with this radio restoration wise to make it look somewhat decent? and what year/schematics/type of radio this is.
And if you know anyone that can do any black magic (literally) on this cabnet, and is reasonable/trustworthy. let me know.
Old 08-25-2008, 10:31 AM
anyone?
Old 08-25-2008, 11:13 AM
jpdylon's Avatar
jpdylon jpdylon is offline
<-- sucker for old sets.
just about anything can be restored, however its all about how much time and money you wish to spend making it happen. Hopefully someone with more experience can chime in and give you the information on that radio.
The first thing I would do is remove the chassis and see what kind of condition it is underneath. Look for signs of serious failure (exploded cap, burned resistor, etc.) If this radio used rubber insulation on the wiring, you'll need to rewire the set. Hopefully the rust and corrosion hasn't gotten to any of the IF transformers.
If the price was right and you have the time and money to restore that set, then great. They are a labor of love, but the outcome can be fantastic. Just remember to document your restoration efforts so people can see and appreciate your work - even if you're not the one to do it all.
Good luck.
Jordan
Old 08-25-2008, 11:38 AM
Valsimot's Avatar
Valsimot Valsimot is offline
excuse my ignorance...
Cute little radio. I'm not tube savvy, but the yellow wire should be the antenna (original was most likely lost over the years). You should contact Tom Bavis, he has a respectable collection of tube schematics.
The inside pic shows a few small holes that might have been made by wood worms, but looks to be clean of any now. That could also explain why it was painted. The grill can be fixed with new small pieces of wood and restored to it's original look ("stitches" would be visible though) or maybe with some wood filler (bondo?) but would then have to be painted.
reality and i agree to disagree.
Old 08-25-2008, 12:15 PM
Well see the electronics isnt an issue. I can restore the electronics much like I have in the past with other radios.
The problem I'm having, is the wood wrok. im not a woodworker, so i cant fix the cabnet damage to make it look like new. I'm looking for someone trustworthy who can.
Old 08-25-2008, 01:12 PM
Fisherdude's Avatar
Fisherdude Fisherdude is offline
The Golden Age of Hi-Fi
I don't recognize that particular model, but I'm guessing it's not particularly valuable. If you want to restore it, it would be a lot of fun, and you would have a very nice sounding and nice looking set.
However, if you paid someone with woodworking and refinishing skills to do the work, you would probably end up paying triple what the restored radio would be worth.
On an unrelated fyi, jpg's don't really compress when you zip them, and not everyone is comfortable unzipping/extracting compressed files.
Pic #26 was originally 462,774 bytes and compressed to 460,446.
Pic #27 was originally 517,829 bytes and compressed to 515,844.
So, you only saved about 1% on the file sizes. Pics are always a great help in ID'ing a radio, so go ahead and post them as jpgs.
Hope somebody can give you a model number and/or a Sam's number so you can get started. Good luck!
I may be growing older, but I refuse to grow up.
Old 08-25-2008, 01:33 PM
the probelm is. as pixels of our cameras grow, the forum attachment sizes do also.
And i had to zip them to just cut them under the 971 kb limit of the zips.
and jpegs they only give you like 115K. whoever is in charge of the administration, it would be nice if they allowed at least over a meg for jpegs.
Old 08-25-2008, 01:35 PM
Like i said before in my earlier post. im not a wood worker. I dont have the knowledge, tools, or facilities to begin on woodworking. if it was me, it would be ductape city. :-)
Old 08-25-2008, 01:47 PM
Tom Bavis's Avatar
Audiophool
Well, first we need to ID it... it doesn't look like an RCA to me (the patent label will always list RCA - they held most of the patents...). Does it say RCA anywhere else? Any labels inside? What does it say on the dial above "Superheterodyne"? The list of tubes MAY help narrow it down - but I'm guessing it uses the usual mid-'30s tubes - 6A8, 78, 75, 42, 80.
Old 08-25-2008, 02:18 PM
ok hang on ill list the tubes... Says World Wide on the dial. I guess becuyase its got AM broadcast, it has the 49mhz band on it, intervened in the same spot as the regular shortwave.
Old 08-25-2008, 02:28 PM
Tube list:
42
6A7
75
80
6C6
3 of them have top anode connections. the 42 and the 80 dont, as 42 is the amp tube, and 80 is the rectifier.
Old 08-25-2008, 03:11 PM
here is a couple pics of the inside.
Maybe these shots will give away what it is? the big orange airline/montgomery ward double lytic maybe? dunno..
also the knob is gone and the shaft is busted/gone on the band select knob. i have no idea where im going to get this from....
Old 08-25-2008, 03:28 PM
I was going to guess Montgomery ward before the second set of photos. It could be...perhaps?? The number 25- 14449 does not seem to match.
Old 08-25-2008, 04:05 PM
it might even be a marconi. who knows. Its probably one of those radios that was probably never seen/documented. rare or not? i dont know. it probably had a tag in the back on the cab that is now gone.
Old 08-25-2008, 04:20 PM
electroking's Avatar
a- v- karma member
Don't wory about that 115k limit. I regularly post .jpg files that are way over
that limit as stored in my computer and they end up being posted anyway.
I guess some kind of compression does take place automatically.
