Old 08-22-2008, 12:27 AM
On those Zeniths there should be an input menu. If it's not there, someone might have gotten into the service menu and told it there is no video input.
This is from an old newsgroup post (I'm not sure if it's correct, but it's close):
To access the service menue from the front panel
press and hold the"menue"key until the menue disappears.Then without
delay press simultaneously the "adjust Right"and "Channel up">Use
"select Up/Down"key to toggle through the menue to go where you want to
go to.Press "Enter"to exit the service menue.(You may have to
press"Enter"twice on some models).
