Old 08-21-2008, 03:34 AM
Originally Posted by MRX37 View Post
Any clue as to what the video inputs are? They can't be composite. I see "Luma" and "Chroma" on some of them, so I assume a spliced S video cable might work...?
Yes, the one marked Video is composite NTSC, and the luma/chroma is S-video and will work with an adapter. For proper display, you need to set the switches to the 75-ohm position (unless you connect additional monitors as I mentioned above). To set the video level controls, first tune in an RF TV signal and adjust the display for good color/contrast/brightness, then switch to your external input and adjust the video level control to match the RF signal. If you use the luma/chroma input, the best procedure is probably to adjust the luma control first with the chroma control at mid-point, then put the chroma control at the same position as the luma control.
