Get a can of freeze spray and hit each part until a difference is noted and replace the part in question. You could have an out of spec resistor or a resistor that is changing value as it heats up.
Also, change the vertical oscillator and output tubes. It's usually not the tubes that cause vertical problems; but, it's worth a try. |
