Old 08-05-2008, 03:35 PM
kbmuri's Avatar
kbmuri kbmuri is offline
Originally Posted by firenzeprima View Post
Si per togliere i graffi dallo schermo bisognerebbe prima passare una carta a vetro tipo 800 . 1000 con acqua, poi con la pasta abrasiva per carrozzieri, poi con il polish. il tutto preferibilmente fatto a mano poichè se viene dato con la spazzola a motore si rischia di surriscaldare la superfice dello schermo e rovinare il pigmento dei fosfori, una volta riparai un tubo che era stato strusciato sul muro, ma ci volle molto tempo per fare un buon lavoro,
----- Google Translate ------
Yes to remove scratches from the screen should be the first one pass glass type 800. 1000 with water, then with pasta for abrasive coach, then with the polish. preferably all done by hand because if it is given with the brush motor is likely to overheat the surface of the screen and ruin the pigment of phosphors, once riparai a pipe that was strusciato on the wall, but we wanted a lot of time to make a good job
Good precaution on accidentally overheating the phosphors. Keep lots of cold water on the tube while working on it.
I would use a diamond-based paper, such as:
http://www.defusco.com/p2071/422-ELE...64u6b5oiikl111
at 1000 or 1500 grit. Then follow with a lapidary product such as:
http://search.ebay.com/lapidary-poli...idaryQ20polish
(remembering at all times that CRT's implode).
Do not attempt to adjust your set.
