Old 07-11-2008, 04:23 AM
myrgatroyd myrgatroyd is offline
AK Member
Well, i think there is no need to do that. Tube rolling is a high end hobby, and I do not believe that the little output transformers and the sounded prestages in our old radios would affect the sound they make... changing the cap coupling the prestage to the endstage could do more... there are only working and non-working ELs... that´s my opinion.
If you had a pp-amp things could be another way. But your Carmen (?) is single ended. (Ah, I see it´s a Turandot, your dial is total different to the german ones.)
There are Telefunken, Valvo, Sovtek, RFT and no-names in my amps. It didn´t change anything.
By the way, did you check your electrostatic speakers? They are known to get week.
Old 07-11-2008, 06:58 AM
jeffsod jeffsod is offline
AK Member
Thank you for the input! I haven't checked the electrostatics but based on the level of highs I am obtaining from this radio at least a couple of them are working properly. This radio has some very unique options for the highs. It has switches labeled 'Presence' and 'Brilliance' which alter the highs in significantly different ways.
