Old 07-07-2008, 01:01 AM
32" Zenith w/ green pix. Needs blue picture tube replaced
I found this on epay. Read the very comical description. I really think this is a 27" instead of a 32"
http://cgi.ebay.com/32-inch-zenith-t...QQcmdZViewItem
Old 07-07-2008, 01:09 AM
MRX37 MRX37 is offline
I think it's also a 27 inch.
I also think the entire CRT needs to be replaced, and that the TV isn't worth 30 CENTS, much less 30 dollars.
Old 07-07-2008, 01:25 AM
I know I need to stop doing this; but, I felt the need to "educate" this seller. I just sent them this message:
Hi, as I fix TV's, I feel you should know that there is no "blue picture tube" in this model. There is only one picture tube that takes care of red, green, and blue. I can assure you that the picture tube is bad in your set, causing the lousy picture. Zenith picture tubes from the '90's have a near 100% failure rate. They will gradually get weak or they will short circuit, which will burn up the power supply and/or video driver circuits. Unfortunately, there is no repair that can be made short of replacing the picture tube. This would cost much more than a new TV. Regards, Bryan
Old 07-07-2008, 01:28 AM
I sent him a message too, saying pretty much the same thing.
I wonder if he'll pull the auction, or try to pawn off his dying TV on some idiot...
Old 07-07-2008, 10:31 AM
I think we got through to him.
"The seller ended this listing early because the item was lost or broken."
I guess he just didn't know what he had. I can't fault him for that.
Old 07-07-2008, 11:37 AM
I did get a nice reply thanking me for the information and they also asked me if they should end the sale. I think this was just a case of the seller not knowing rather than them trying to put their junk off on someone that didn't know any better. I can't fault them for not knowing. Everyone is not a TV "expert" like we are, LOL!
