Old 08-12-2004, 12:07 AM
reeferman's Avatar
Need a fusible resistor
Anybody have 1 ( or 2 ) of a .1 ohm @ 1/2 watt fusible resistor they could send via snail mail? I'll reimburse you for it. Thanks
Old 08-12-2004, 01:06 AM
EchoWars's Avatar
EchoWars EchoWars is offline
Once Ran Amok in Kent
Extremely oddball value in an extremely difficult to find package. Vishay makes fusable resistors, but NOT a 0.1 in a 1/2W (the best they have is a 2W wirewound), and they make everything...
Forget the fusable part...I've never seen a fusable resistor save a bloody thing...transistors blow way too fast for a fusable resistor to help.
Huntington Electric has a 1W 0.1 ohm 1% resistor that should be fine as long as the physical size isn't a problem. It measures about 2.8mm in diameter by 9.8mm long. Digikey part #ALSR1F-.10-ND
In battle, in forest, at the precipice in the mountains,
On the dark great sea, in the midst of javelins and arrows,
In sleep, in confusion, in the depths of shame,
The good deeds a man has done before defend him.
--Bhagavad-Gita
