Old 06-17-2008, 06:35 PM
Robert Grant's Avatar
Robert Grant Robert Grant is offline
CTI Line Sequential was not like SECAM.
In Line Sequential color, each line represents one of the primary light colors (green, blue, red) whether the image has colors or not.
SECAM was actually more like NTSC than you might think. Like NTSC (and PAL), there was a luminance (or Y) signal that was compatible with monochrome recievers (in the case of SECAM, 625x25 then in service in Europe) that was not sequential and thus as flicker-free as monochrome TV.
The sequential refers to how the color subcarrier is transmitted. In SECAM, either R-Y or B-Y is transmittted as an *FM* video subcarrier on each line, and the subcarrier from the previous line is saved by a delay line (hence the "a memoire") and carries the opposite signal (B-Y or R-Y) to the color matrix, presenting the matrix with luminance, R-Y and B-Y (from which all colors can be mathematically derived) on each line. This gives SECAM (and, BTW, PAL) less "color resolution" in the vertical plane than NTSC, but, like horizontal color resolution, was deemed not-as-critical as lunimance resolution.
One disadvantage of SECAM is that it does not work well with character generators, or mixing of video. In SECAM countries, video production is generally done in RGB and only encoded into SECAM at the transmitter.
Rob
