Do you have a degaussing coil? It may just need degaussing.
The effect is called "doming".
Doming is a phenomenon found on some CRT televisions in which parts of the shadow mask become heated. In televisions that exhibit this behavior, it tends to occur in high-contrast scenes in which there is a largely dark scene with one or more localized dark spots. As the electron beam hits the shadow mask in these areas it heats unevenly. The shadow mask warps due to the heat differences, which causes the electron gun to hit the wrong colored phosphors and incorrect colors to be displayed in the affected area. |
Wasnt there a capacitor problem in these sets that caused this symtom?
-Tony |
http://en.wikipedia.org/wiki/Doming_%28television%29 In some cases, a new purity adjustment might fix this problem. Eckhard |
Doming usually does not affect the delta's, mostly later inline tubes with slotted shadow masks. Probably the condensor. |
