Chances are your PBS station is a low wattage signal that is too distant for your antenna. You will need to go to a roof type antenna to get weak signals. Even then the weak signal stations will have good days and bad days. This has been my experience with our new "improved" system. The poor and the remote won't have much to watch after February, 2008.
Sansui G6000,7070 Pioneer SX1250,SX1280 Kenwood KR-8010 Onkyo TX8500II Pioneer CTF950,Akai GX-S80 DCM TF-600,TF-400 CX-17+ KL Quartets |
One thing I have found is that you really need to use a UHF-specific indoor antenna to reliably get UHF DTV stations...either the UHF lead coming out of a rabbit ear set that has both a loop antenna and the "ears" or even better, a bow tie type reflector antenna. When trying to use a VHF only rabbit ear set to get UHF I have gotten no signal at all or poor reception but with the UHF Loop it has come in fine.
I'd recommend the bow tie type which has two bow ties plus a rear reflector and is gold in color. One setup I have used in a downtown building where reception is really tough is to put the indoor antenna in a window and use a balun to connect it to 75 ohm coax which runs to the DTV receiver. Putting it in the window and adjusting for best orientation has made a big difference in signal quality. |
