Old 05-26-2008, 09:50 AM
ccheath's Avatar
ccheath ccheath is offline
Got an Idea!
I don't think the cable can be fixed. Even the finest magnet wire I can work with looks like a wire coat hanger next to the damaged traces. There are 12 traces in about 4 mm.
The cable can't be replaced because it contains the column driver ICs, and the other end is glued to the plasma screen.
If I got nothing to lose, I just get creative on how to get that cable fixed since it "can't" be replaced. If it were mine, I will fix it no matter how hard it is. That is "IF" I got nothing to lose. I have no patience for having a white bar in the top middle of my screen while watching.
I hate taking things to shop. They may fix it alongside with making many more scratches on the equipment. Years ago I had a car amplifier and it quit getting inputs so I took it to the shop under warranty. When I got it back, it worked for awhile then same problem as before. Since it was out of warranty then I check what's under the hood and found they used very fine solid wire that was for sure to break onto RCA jacks. There's a saying "You want things done right, you do it yourself." That's what I do until I reach my limit.
