Old 07-28-2004, 10:47 PM
peverett peverett is offline
I am working on a Hoffman with the high voltage rectifier and flyback under the chassis. This Hoffman has a removable bottom to allow you to change this and the tuner tubes. It also has several black beauties which I am changing. I have removed a couple with nice cracks down the sides.
Another interesting feature of the Hoffman is that it has a transformer for the filiments but uses a selenium rectifier voltage doubler for the DC power supply. This supply is not isolated so the entire metal chassis could be 120 volts. All except one of the controls, front and back have insulators between them and the chassis and the chassis mounts on plastic insulators. I am guessing that the one control is not original.
Of course I am using an isolated variac to work on this set.
