Sounds like the CRT needs degaussing. Also, check the degaussing thermistor inside the TV for loose solder connections to the PC board. The degaussing thermistor is located in the power supply, close to the two lead plug leading to the degaussing coil around body of the CRT. The thermistor will probably be a small, black square case.
