Old 05-06-2008, 07:13 AM
Old1625's Avatar
Old1625 Old1625 is offline
Did you have a raster after the resistor smoked, or only before?
Some sets (color ones, at least) take a DC voltage output from the audio-output circuit/tube, so such a setup could be part of your problem.
Yes, many set makers used the audio output tube as a voltage regulator, drawing about 150 volts off its cathode.
The burnt resistor needs to be replaced, and the cause of its demise determined, before carrying on in troubleshooting the missing raster. In some sets this cathode feed supplies the tuner, the pix IF chain and the video amplifier stages.
