Old 04-14-2008, 10:42 PM
matt_s78mn's Avatar
matt_s78mn matt_s78mn is offline
Ahh 3/4" ...this format has been around for ages, and believe it or not there are a lot of facilities still using it. At my job we have 3 remaining decks that I have to maintain. They're in the edit bays, and really only used when a news story calls for archive footage. (our entire archive is on 3/4") Even though they're not used all that much, they still go through belts like crazy!! Even though the format's on its way out, I'll never forget the "clunk, clunk, clunk" when you load a tape.
To avoid veering off topic... You do see the U-Matic logo on the later tapes from other manufacturers. I've included a picture of a Maxell bearing the U-Matic SP logo. I'm thinking Sony must have ok'd its use at some point in time.
Also, for forum members that are unfamiliar with the U-Matic format, cassettes are available in two physically different sizes. The smaller sized cassette was designed for portable recorders, and the larger for studio use. The recorders/players designed for studio use can play both cassette sizes (without the use of an adapter.) You'll notice the red dot on the photo of the underside of the large cassette... That's the record prevention tab. If you want to prevent the tape from being recorded over, pop it off, put it back on if you wish to record on the tape.
