Old 04-13-2008, 10:29 PM
Tugboat Tugboat is offline
Banned
Question Zenith CC II 19JC55Z Circuit Breaker tripping
First off I'd like to say hello to everyone here. This is my first post.
I got this set from my sis-in-law a year ago. She got it back in '77. Over the past year I have been using it with my RCA VDT-350 VHS and RCA SJT-200 CED player. For most of that time the set ran pretty will with the occasional drop in brightness and it could have used a touch up on the convergence. That is, until the other day. Out of the blue while watching The Love Boat, the screen went blank and the circuit breaker blew. I reset the breaker and the channel number lit up for about 5 seconds and the breaker tripped again.
Now I hope you'll hang in with me here as all I currently know about fixing TVs I've learned over the past two days from the unit's service manual and searcing the web.
Upon inspection I noticed that the video ouput board on the neck of the crt was smoking from the center as the breaker tripped. I removed the board and opened the white ring that contains the spart gap and it was pretty black and had a small opening in it from arching. From what I've been able to figure out, that gap has something to do with the HV for focus? I've inspected the tripler and find nothing out of the ordinary, but it's hard to know since the breaker only gives me about 5 seconds before tripping. During that time I hear nothing. I only see and smell smoke from the spark gap.
Any help from this point forward would be greatly appreciated. How can I go about finding the bad component? So far I've come up with either a bad tripler or CRT (both of which I can purchase replacments for from Sears). The CRT is 19VGZP22 and $128. The tripler is 977-43 and $60.99. I don't know if these prices are high, but they are Zenith parts.
If you need any other information to help, please let me know and I'll do my best to get it to you.
Thank you!
Robert
Old 04-13-2008, 11:36 PM
I seem to remember the Tripler shorting and putting the full 25 KV on the focus lead; thus, burning up the spark gap. You will probably need a new tripler as well as a new CRT socket. One thing you might try is unsoldering the input lead from the tripler. This is the lead coming from the flyback transformer to the tripler. You will have to cut away the RTV where the lead solders on the tripler and then unsolder the lead from the tripler. Use extreme caution when doing this. Now, make sure the lead is away from the chassis and turn the set on. You should now have sound and the breaker should not trip. If it trips, you have problems elsewhere in the set. Power up the set as little as possible in it's current state because I've also seen shorted triplers burn up the flyback in the CC II's.
I wouldn't jump off into paying those prices for those parts without checking around first. Someone on here may have what you need for a better price. In fact, I'm shocked that Sears would have any parts for such an old set.
It would be nice if you had access to a CRT tester just to make sure the tube was OK before buying the other parts.
Old 04-13-2008, 11:53 PM
Banned
I should be able to handle desoldering the input lead on the tripler. For safety sake, will grounding the anode on the crt to DAG (did I get that right) remove all the HV down to the wire I'm about to mess with? If not, how would I go about doing so?
The lowest price I found for the tripler was $45 and was only able to find the CRT through Sears. Hmmm..... I inspected the CRT socket and the burn from the arcing didn't melt all the way through the cover. Is it a good idea to replace it anyway? If so, I'll start looking for one.
As for the CRT tester. I see a number of them on ebay, but I have no idea which model/make would work with my tube. That and most of them are untested.
Thanks for your help!
Old 04-14-2008, 12:29 AM
That tripler crosses to a ECG559 or NTE559. An NTE distributer should have it.
Yes, you can discharge the CRT by shorting the anode connection to the dag ground. You might want to attach a wire to an insulated screwdriver and connect the other end of the wire to dag ground. Holding the screwdriver by the handle, slip the end under the anode cup. You may hear a loud POP as the CRT discharges. Repeat this procedure several times to make sure all the charge is gone.
If you get a CRT tester, try to get a B&K model 467 or later model number. The older ones usually do not have the socket to test the inline tube like what is in your set and their rejuvenate function is not that great. A Sencore CR70 is another good choice. Like you said, the ones on epay are usually untested and you could easily wind up spending big $ on a piece of junk. Someone on this forum may have something they would sell you that would stand a much better chance of working than that crap on epay.
Maybe someone here on AK with a CRT tester is close to you (I'm in MS) and could check your tube. Another option is to find an older TV shop that could check your tube. Most of the newer shops would laugh in your face and tell you to s**tcan it if you brought that set to them. But, I'm here to tell you that your Zenith is far better than most any TV made today!
Old 04-14-2008, 12:33 AM
Here is a link to a tripler for $31.80
http://www.web-tronics.com/nte525tonte815.html
Old 04-14-2008, 12:37 AM
BTW, if you buy a B&K CRT tester, make sure is has adapter CR-20 with it. That is the socket to test your tube. I think B&K discontinued these older adapters in favor of a "universal" adapter that is nothing more than clip leads that are designed to clip on the pins of the CRT.
Old 04-14-2008, 03:03 PM
Banned
I checked ebay and the testers are lower model numbers than the one you gave. I'll keep check back.
I live in Hollywood, CA and there aren't many repair shops left. The couple I found and contacted wanted upwards of 75 diag fee.
I'm gonna tackle the disconnecting of the tripler in a bit (must finish my taxes first). I'll let you know if the set comes to life without the CB tripping. If it does, does this indicate the tripler only, or could the problem still be in the tube or the horizontal ouput board?
Thanks!
Old 04-14-2008, 03:50 PM
Banned
Okay, I removed the input wire to the trippler, secured it and tested the set. It worked without tripping the breaker and I had sound. So I guess the issue is in either the CRT or HV somewhere. Funny thing is that when I connected the wire and put the screwdriver under the cup, I hit the connection under the cup but there was no signs of any discarge. Is there usually a discharge?
Should I order a replacement tripler, or should I diag a little more first?
Thanks!
Old 04-14-2008, 04:02 PM
If it comes to life, it means the tripler is likely bad. I suspect you'll also need to replace the CRT socket since the spark gap is badly burned. Don't let that lead from the flyback come near the chassis. There is around 9 KV on this lead and it can arc to the chassis if it's too close. There is really no way of telling if the tube is bad without changing those other parts if you don't have a CRT tester. The only way I could see the tube being bad in this case would be if the tripler shorted and threw 25 KV onto the focus electrode inside the tube. The focus voltage is somewhere in the 8 KV area and the 2nd anode voltage is around 25 KV. Maybe the spark gap prevented the excess voltage from ruining the tube.
Old 04-14-2008, 04:44 PM
Banned
Is there a way to test the tripler? I tried to measure resistance in it, but got nothing on any of the leads. Figured there should be something to measure in the unit.
I'm going to order a replacement tripler today.
Thanks
Old 04-14-2008, 04:55 PM
I've never found a way to test a tripler other than unsoldering the input like I mentioned. Of course, there are the ones that the case is cracked or buldged and those would be bad.
Old 04-14-2008, 05:20 PM
Banned
I ordered the tripler and now need to wait for it to be delivered. I should get it by Friday, so I'll put the set aside and wait.
Thanks for all your help. I'll post back when I get the tripler.
Old 04-14-2008, 05:31 PM
Old 04-14-2008, 06:39 PM
Banned
I'm going to install the new tripler and if that doesn't fix the problem, I'll assume the tube is bad and replace the set. I wanted to make an effort to save the set as it's been with my sis-in-law for over 30 years and she's been in my family for over 22 years. This set's been a good friend.
I think I'll make the rounds at the thrift stores and see if I can find a nice 25" console if this CRT is bad. I'll put this unit away until I find a replacement CRT.
Thanks!
Old 04-14-2008, 08:50 PM
If you can't find a new CRT socket, clean that spark gap the best you can. Rubbing alcohol usually works. Just make sure it's completely dry before powering up the set.
I'm curious to know if your set is a remote set, a one knob tuner, or the standard two knobs for VHF and UHF?
If you look for a '70's console; a Zenith Chromacolor or Chromacolor II would be a good choice. They use a delta gun tube and they almost never go bad. The triplers do fail; but, I've never seen one in the delta tube sets send the second anode voltage through the focus lead. They either arc and burn or they short, killing the HV and tripping the CB. The '70's RCA consoles are decent sets if the CRT is still good. I've seen way more bad RCA tubes than Zenith.
