If you're going to repair television sets, you're going to have to learn how to discharge a picture tube. It's not hard, nor is it dangerous. And if you do get zapped, remember, it's low current. It'll hurt like hell, but it won't kill you.
Just ground a screwdriver with a cliplead, and slide it under the suction cup. You'll hear a loud ZAP! Do it again, just to be sure. The suction cup is held to the tube with two little metal tabs that go into the hole in the side of the tube. It's a lot like how the top is held on Christmas ornaments. Squeeze the tabs together and rock them out of the hole. I typically have a "discharge tool" handy. It's just a screwdriver with a length of lamp cord connected to it, and the shaft wrapped in tape. The end of the lamp cord has an aligator clip on it. And yes, I've been bitten. By a computer terminal that I _thought_ wasn't producing any high voltage. It was. It hurt, made my arm twitch pretty good, and I felt it afterwards for a good hour or so. But, I'm not dead. And now I'm more careful ![]() -Ian |
Yep, you must be able to safely drain the HV in this hobby.
Here's how I do it... You know those 2-in-1 screwdrivers, with philips and flat, and one type fits into the handle when not in use? I threw the (small) shaft aside and cut a flat-head 2-3 foot shaft from another. I got bare copper wire about 18awg, and wrapped the length of the screwdriver shaft with it. I then stuck in the enpty handle, and it fits very snuggly. It's been my hv drainer for about 2 years, try it. And as Andy mentions--don't drain HV to chassis ground especially in a modern set since it will likely fry IC's and EEPROMs. BTW I must be nutso, because I've shipped far bigger things to far more distance places than that 169! |
In this day and age, if the tube is bad, it's generally not worth fixing anyway unless you have a spare CRT handy. I mean, are you gonna go through the trouble of replacing the CRT in a BPC Magnavox, or RCA, or Zenith TV, when you have 5 of them already that work fine, and you find another one or two of them every trash day? I don't mind fixing problems with the board or power supply if I can, but CRT analog TV's are a dying breed sadly, and to me it's not worth messing with them if the CRT is shot. |
I was telling the telephone lineman about me getting shocked spicing telephone wire with my teeth. He said your lucky the line was not in ring mode. If the telephone rings the line produces more voltage. (replying about discharging picture tube voltage)
![]() -Ian |
