ctc169 is the best rca ever made. a good bump with a quality crt restorer will bring that tube back up. they were also some of the best crt,s ever made by anyone period. this set wasent that bright when new. but they are a hell of a set. steve
that set also cost about 2 grand new. steve
The dim picture is only part of its problems. The picture also has color bleeding, convergence issues around the edges, and a chip in the screen missing. So the tube is junk. |
The 121 was a very solid chassis IMO. I picked up two over the past few years and one had an intermittent red short but I cleared it up and gave it to a friend. They did make great pictures.
Yep, I believe that. The one that I have, I found sitting in wet gress, it had been raining that day so I'm pretty sure water got inside it. I let it dry overnight, then fired it up and it worked fine.
The CTC185 chassis isn't bad either, once the well-known issues with the onboard tuner are corrected. I have one of these sets with a 19" CRT and it's worked great the last eight years (bought it new in 1999). Only had one repair done on it in all that time. I once read somewhere on the Internet that once the on board tuner issues are repaired, the TV will work for years, as this was the biggest major problem this chassis had; the way mine has been going so far (knock on wood), I believe it.
